Keeping existing plug-ins during install of 1.3.13
I'm about to upgrade from 1.3.12-beta (Unicode) to 1.3.13. In my Windows/Programs folder, the Audacity folder has a sub-folder for plug-ins. Will these remain in place during the upgrade install, or do I need to move them out of the way before the install and put them back after the new version is installed?
Re: Keeping existing plug-ins during install of 1.3.13
Move them out of the way, or rename the existing plug-in folder before you update Audacity.
I usually just rename the folder as "plug-ins-old", then copy plug-ins over from "plug-ins-old" to the new "plug-ins" folder after updating.
