Beep-Beep noise in recordings
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Old Bob
Post by Old Bob » Mon Apr 11, 2011 11:33 pm
Help! I occasionally end up with a recording with a beep-beep noise in the background, quite audible, renders the recording useless. Sounds like Morse Code: repeated pattern through the whole thing. Happens on one computer only, and this computer will play back a different recording just fine, so it seems to be in or during the recording process. Any chance this is a setup issue?
I'm baffled.
Re: Beep-Beep noise in recordings
Post by steve » Mon Apr 11, 2011 11:47 pm
It could be that the recording is picking up interference from somewhere.
What sort of computer is it, what are you recording?
If it's a laptop computer, try running it on battery while you record - laptop power supplies frequently cause interference.
If possible, try moving the computer to a different location, as far as possible from where the bad recordings occurred, then make a test recording.
