Clicks on VO track recorded w/ music
BillA
Post by BillA » Thu Apr 07, 2011 12:59 am
Using Win XP Pro, SP3, with Audacity 1.2.6
I have imported an MP3 recording of music using:
Project -> Import Audio
It appears as a stereo track.
I MUST record a voice-over (VO) track while I listen to this music; the two must be coordinated.
I press the record button and start the VO. When I do this, the VO recording levels are below clipping level. The VO sounds fine in the headset I am using.
But when I listen to the VO track soloed, it is riddled with clicks.
I have tried everything I can think of to defeat this artifact, including turning down the music playback.
When I record the VO alone, without the music track, it is fine, with no clicks at all.
Any help would be much appreciated.
Best regards,
Bill A
Re: Clicks on VO track recorded w/ music
Post by steve » Thu Apr 07, 2011 7:35 pm
Are you using a USB microphone? If not, what?
BillA
Post by BillA » Thu Apr 07, 2011 8:39 pm
steve wrote:Are you using a USB microphone? If not, what?
No, I'm using a headset mic that came with Dragon NaturallySpeaking 11, that plugs into the microphone connector via a miniplug (I believe that is what it is called) on the front of the PC, which goes to the PC's sound card.
Many thanks for responding, Steve.
Best regards,
Bill Amatneek
Post by steve » Fri Apr 08, 2011 9:46 am
Could you post a short sample to illustrate the problem.
  • Select a short section of the voice track (just a couple of seconds)
  • From the "File" menu select "Export selection as wav..."
  • Upload the exported file to the forum using the "Upload attachment" forum feature (below the "compose message" text box).
Post by Gale Andrews » Fri Apr 08, 2011 4:49 pm
BillA,
This situation is quite common. Have you tried the tips in Recording Troubleshooter ?
Does the recorded voice-over track include only what you recorded, or the music as well? If it includes the music, change the input source in Audacity Mixer Toolbar to record from the mic, not stereo mix or similar.
BillA
Post by BillA » Fri Apr 08, 2011 5:36 pm
Gale Andrews wrote:BillA,
It is the VO only, no music.
Best,
BA
P.S. My thanks again, Gail, and apologies for being anxious to receive a response.
BillA
Post by BillA » Fri Apr 08, 2011 9:38 pm
steve wrote:Could you post a short sample to illustrate the problem.
The file is attached, Steve.
Thanks very much.
Best,
Bill A
Clicks on the track.wav
Clicks on the track.wav attached
(857.18 KiB) Downloaded 48 times
Post by steve » Sat Apr 09, 2011 9:33 am
The clicks are due to "drop-outs". This is where the computer system is not running fast enough to record continuously, so breaks / skips / discontinuities occur in the recording. Here is a close up of one of the clicks:
As Gale suggested, look at the "Trouble Shooting" page, and in particular the section about "skips" http://wiki.audacityteam.org/w/index.ph ... ings#Skips
BillA
Post by BillA » Sun Apr 10, 2011 6:46 am
steve wrote:The clicks are due to "drop-outs". This is where the computer system is not running fast enough to record continuously, so breaks / skips / discontinuities occur in the recording. Here is a close up of one of the clicks:
Steve, thank you very much for your insightful analysis of this problem. I will try the solutions in the Skips section.
Best regards,
Bill A
