Hiding Metadata editor on export
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
golinux
Operating System: Linux Debian
Post by golinux » Mon Apr 04, 2011 5:00 pm
The option in preferences to show/hide the Metadata editor isn't working. I looked in the cfg file and there is nothing in there for the metadata editor. What can I add to the cfg file to hide it when I export a track?
Thanks.
waxcylinder
Re: Hiding Metadata editor on export
Post by waxcylinder » Mon Apr 04, 2011 5:26 pm
Well it works fine for me in 1.3.12 and the latest Alpha nighly build of 1.3.13 - go to Edit > Preference > Import/Export and you should see a check-box titled "Show Metadata Editor prior to export step" - ensure that this is checked off.
There was briefly an earlier 1.3.13 which did not honour the setting of that check-box but that was fixed many Alpha releases ago.
golinux
Post by golinux » Mon Apr 04, 2011 6:02 pm
waxcylinder wrote:Well it works fine for me in 1.3.12 and the latest Alpha nighly build of 1.3.13 - go to Edit > Preference > Import/Export and you should see a check-box titled "Show Metadats Editor prior to export step" - ensure that this is checked off.
That's what I did. It's not 'sticking'. I can just add it to the cfg file if someone gives me the code. :)
Post by steve » Mon Apr 04, 2011 6:12 pm
Code: Select all
[AudioFiles]
ShowId3Dialog=0
(The [AudioFiles] section probably exists already, so just put ShowId3Dialog=0 in that section).
golinux
Post by golinux » Mon Apr 04, 2011 10:52 pm
steve wrote:
Code: Select all
[AudioFiles]
ShowId3Dialog=0
Thanks!
Well, I discovered that code (now that I know what it is) was actually already in there but it's not working. :( Is there a cache somewhere that needs clearing?
Post by steve » Mon Apr 04, 2011 11:12 pm
Which exact version of Audacity are you using? (Help menu > About Audacity)
golinux
Post by golinux » Tue Apr 05, 2011 12:37 am
steve wrote:Which exact version of Audacity are you using? (Help menu > About Audacity)
1.3.4-1.1 according to Synaptic. You might remember I downgraded to get rid of those nasty green lines . . .
Post by steve » Tue Apr 05, 2011 1:26 am
Oh yes I remember. Unfortunately it looks like you've run into another old version bug.
Were you planning to upgrade your OS soon?
bgravato
Post by bgravato » Tue Apr 05, 2011 2:08 am
If I remeber correctly he was about to switch do debian... But I'm assuming he hasn't done it yet... Current audacity version on debian stable is 1.3.12.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
golinux
Post by golinux » Tue Apr 05, 2011 3:58 am
steve wrote:Oh yes I remember. Unfortunately it looks like you've run into another old version bug.
Drat! That's what I figured. I'm nearing the end of a HUGE video remastering project that I've been at for about two months. I don't want to start mucking around OS/hardware until it's finished, committed to disk and backed up. Should be about another 2-3 weeks. I'm assuming the aup files are backwards compatible? Don't want any nasty surprises down the road. :)
Oh and BTW . . . it's a she and an old one at that! :o
