Couldn't write to file "/home/username/.audacity/AutoSave...
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Argh
Post by Argh » Mon Apr 04, 2011 2:59 pm
When I load up an audacity file (importing from OGG) and edit it, I get this error message:
Couldn't write to file "/home/argh/.audacity-data/AutoSave/2011 04 03 Morning - 2011-04-04 10-34-28 N-1.tmp": Error opening file
Any ideas why? :?: :?: :?:
Thanks! ;)
bgravato
Operating System: Linux Debian
Re: Couldn't write to file "/home/username/.audacity/AutoSav
Post by bgravato » Mon Apr 04, 2011 10:30 pm
Which audacity version? You posted in the 1.2.x section of the forum, so if you're still using such an old version of audacity it could be due to the spaces in the filename...
It could also be that you don't have writing permissions in that folder, but that appears to be your homedir so that shouldn't be a problem. It could also be that you're running out of disk space in that partition...
If you're still on audacity 1.2.x it's highly recommended that you upgrade to 1.3.12.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by steve » Mon Apr 04, 2011 11:20 pm
Does the folder "/home/argh/.audacity-data/AutoSave/" exist?
Are you logged into the computer as "argh"?
Did you launch Audacity as a regular user? (you should not run Audacity as root)
Argh
Post by Argh » Tue Apr 05, 2011 11:51 am
bgravato wrote:Which audacity version? You posted in the 1.2.x section of the forum, so if you're still using such an old version of audacity it could be due to the spaces in the filename...
You're right -- I posted the wrong place. In any case, I am using 1.3.12
HA! It WAS the permissions. I made sure the permissions of /home/username/.audacity were set for me, and clicked to apply that to the enclosed files, but nautilus (in Ubuntu) didn't apply those permissions to the enclosed folders. :shock: I manually reassigned the folders to me and it works.
Thanks! :D
Again -- sorry for posting the wrong place. :oops:
bgravato
Post by bgravato » Tue Apr 05, 2011 12:56 pm
Moved to the 1.3.x section of the forum.
Glad to know you sorted out your problem :)
