Can I record and have it stop when there is silence?
feelthebeat
Re: Can I record and have it stop when there is silence?
Post by feelthebeat » Tue May 10, 2011 5:39 pm
How is it possible to define the length of the silence, because there might be short "blanks" in a conversation and then its starts again.
What's the final answer then ??
If it is "No, but I think there's a feature request for that... shall your vote be added?"
URL please ?
Post by steve » Tue May 10, 2011 5:52 pm
The answer is, upgrade to Audacity 1.3.13 http://audacityteam.org/download/
and use "Sound Activated Recording" http://manual.audacityteam.org/man/Transport_Menu#sar
feelthebeat
Post by feelthebeat » Thu May 12, 2011 12:29 pm
Done
Well, maybe I missed a point, all I see is that I can set the db activation level, unfortunately this is NOT an answer to my question.
To reformulate:
Say I set the activation level at -42DB.
A person starts talking, Audacity records, after a while this person pause (i.e. stop talking, usually in order to think or for a memory recall) let's say during 3 seconds, then continues.
I do NOT want Audacity to stop recording, because the activation level is breached for 3 sec, I want to set the stop recording when both one is under the activationg level AND this perdure for a given time, let's say 10 sec ! This is something as:
Function triggerStop()
If ( inputSound < -42 DB ) THEN
While (elepasedTime < 10sec)
if ( inputSound > -42 DB ) THEN triggerStop=FALSE; exit triggerStop();
EndWhile
triggerStop=TRUE
ENDIF
EndtriggerStop
This is quite common in radio or conferences and later one can work on the sound file if need be. Silences do have a lot of meaning.
Post by steve » Thu May 12, 2011 7:29 pm
feelthebeat wrote:all I see is that I can set the db activation level
That's correct. I thought everything else had already been covered in the previous posts.
I've added your vote here: http://wiki.audacityteam.org/wiki/Featu ... hest-rated
Sound Activated Recording (currently in Audacity Beta only)
* Pre- and post-roll duration: define a duration to be recorded before the threshold-level sound occurs, and similarly a duration to be recorded after the input falls back below the threshold. Requires buffering of the recording for pre-roll, but is expected behaviour for this type of tool. (30 votes)
