I did know how to do this but I frgot.
I put my Cursor at the stop I want it to end.
So I know everything to the Left is what I want to keep.
So I go to Edit and then Select and pick Select to Left of Posion.
And a box opens with how long in seconds already has played so I click ok.
It does not wok.
I think I have it but I know I just need help on how to do it right.
I forgot a step I think?
select audio help
Re: select audio help
To select from the start to the cursor position, press "Shift+Home key".biferi wrote:I put my Cursor at the stop I want it to end.
Thanks for the help.
But I thought you could some how do it the other way?
"Edit menu > Select > Start to cursor"
