Vox synth pads
Murky effects
Vox synth pads
Hey. One of the things I use Audacity to do is make Soundfont files.
Im wondereing if anyone knows the basics from making vox string synth style sound?
What kind of equalization? and what kind of tone to start out with?
Saw, square, sine, or other?
Any Ideas?
Thanks.
Any Ideas?
Thanks.
Re: Vox synth pads
Many of the old analogue style string pad sounds were created using Pulse Width Modulation (PWM).
The easiest way to generate PWM sounds in Audacity is to use "Nyquist" code.
See here about "Nyquist" programming in Audacity: http://audacityteam.org/help/nyquist
Try selecting part of an audio track, then from the "Effect" menu select "Nyquist Prompt".
Copy and paste the following code into the Nyquist Prompt box, then click "OK"
Code: Select all
(mult (pwl 0.1 1.0 0.6 1.0 1.0)
(sim
(mult 0.4 (osc-pulse 110 (sum 0.35 (mult 0.4 (hzosc 56.2)))))
(mult 0.3 (osc-pulse 220 (sum 0.35 (mult 0.4 (hzosc 110.5)))))
(mult 0.2 (osc-pulse 440 (sum 0.45 (mult 0.4 (hzosc 221.5)))))
Murky effects
Re: Vox synth pads
Cool thanks , Ill try it out.
Murky effects
Re: Vox synth pads
K Iv'e noticed the Pulse-width modulation Nyquist code generates it's own wave. I wonder is there any way to use it as an effect over a sound?
rather than have it generate a wave.
Also could you please tell me what each number changes in the code so I can better understand how it works?
Re: Vox synth pads
Yes that was a "generator" rather than an "effect".
For generating a "string pad" type sound you need a lot of overtones/harmonics. You could start with one or more square waves or triangle waves, or saw waves, to produce a rich frequency spectrum (additive synthesis), or you could start with sound generated using "Pulse Width Modulation". The code that I posted contains 3 PWM generators and a simple envelope shaper.
The "sim" function (simultaneous) combines the three sounds (mixes them).
This is the first generator.
It is made from a pulse oscilator (osc-pulse).
The basic way that the pulse oscilator works is that you define the frequency, and the width of the pulse.
(osc-pulse <frequency> <width>)
So the frequency of this oscilator is 110 Hz.
The "width" parameter (more accurately called the "bias" parameter) is a value between +/- 1
If the bias parameter is zero it will create a square wave - try the following code in the Nyquist Prompt:
This produces a full-scale square wave with a fundamental frequency of 100 Hz.
It's easy to scale the amplitude of a sound, simply by multiplying the sound by a number less than 1. So if we want a half height square wave with a fundamental frequency of 440 Hz we could write:
If the pulse width is less than zero, the pulse will be negative more than it is positive, for example:
Here's some other oscillators:
and a generator that is not an oscillator - any guesses what this does?
I'll have to get back to you with the rest of the explanation later in the week as it's now late and I have to be up early tomorrow.
Code: Select all
(sim
<sound 1>
<sound 2>
<sound 3>
)Code: Select all
Code: Select all
(osc-pulse 100 0)It's easy to scale the amplitude of a sound, simply by multiplying the sound by a number less than 1. So if we want a half height square wave with a fundamental frequency of 440 Hz we could write:
Code: Select all
(mult 0.5 (osc-pulse 440 0))
Code: Select all
(mult 0.5 (osc-pulse 440 -0.5))
Code: Select all
(mult 0.8 (hzosc 440))Code: Select all
(mult 0.4 (osc-saw 220))Code: Select all
(mult 0.9 (osc-tri 88))Code: Select all
(mult 0.5 (noise))9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
Re: Vox synth pads
Sounds like a job for a ring modulator ...Murky effects wrote:... is there any way to use it as an effect over a sound? rather than have it generate a wave.
Alternatively modulate with a more complex waveform by applying Steve's amplitude modulation code.
