Audacity froze while I was saving a recent 3-minute project. I retrieved all the files from the tmp folder after restarting Audacity and they are sitting in a folder on my desktop. I was wondering where to go from here.
Thanks in advance,
John
Frozen While Saving
Re: Frozen While Saving
Stop using Audacity 1.2. Audacity 1.2 is very old and is no longer supported, patched, upgraded or corrected. It can be profoundly unstable on newer Macs.
Get Audacity 1.3.12 and any software plugins (lame, FFMpeg, etc.) from here...
Audacity 1.3 projects will not open in 1.2. You can safely put both versions on your machine, but only use one at a time.
Thanks for the quick reply. I wasn't even aware of the 1.3.12 beta. I really appreciate all you guys do
Audacity 1.3 has greatly increased disaster recovery tools over 1.2, so the short answer is your show is toast, unless your 1.3 account can do anything with the files.
Crash Recovery
http://audacityteam.org/wiki/index.php? ... shRecovery
Crash Recovery
