Audacity fails to open after installing swh-plugins
This section is now closed
JLoz
Post by JLoz » Sat Jul 26, 2008 6:44 pm
I installed Audacity 1.2.6, opened fine. Then I downloaded swh-plugins and installed.
Audacity refuses to open after this. Can't find where these plug-ins went on the HD.
Using Mac version OX 10.4.11
Any clues?
happywoman50
Re: Audacity fails to open after installing swh-plugins
Post by happywoman50 » Fri Aug 01, 2008 1:18 pm
Maybe you should try to reinstall Audacity 1.2.6.
Ann, my blog is here
Post by steve » Fri Aug 01, 2008 5:02 pm
The plug-ins should go in the plug-in folder which is in the Audacity program folder.
