Help, recording streaming internet radio
TinPan
Re: Help, recording streaming internet radio
Post by TinPan » Thu Mar 31, 2011 7:44 pm
Ok, those 2 box's are now checked, no change.
TinPan
Post by TinPan » Fri Apr 01, 2011 9:37 am
Still no record
Post by steve » Fri Apr 01, 2011 11:06 am
TinPan wrote:Ok, those 2 box's are now checked, no change.
With those two tick boxes selected, what recording devices are listed? Have any new options appeared in that recording tab?
TinPan
Post by TinPan » Fri Apr 01, 2011 11:33 am
Not sure which one should be selected
Microphone
CD player
Line in
SPDIF in
Aux
Stereo Mix
Wave
In the right clicked box with the two check box's
Disable
Set as default
Show disabled devices (checked)
Show disconnected devices (checked)
Properties
TinPan
Re: Help, recording streaming fixed! However
Post by TinPan » Fri Apr 01, 2011 12:37 pm
Ok, I found the problem, it was in "set up" so I have it recording but the station sounds like it's in a reverb chamber. What is causing that?
Post by steve » Fri Apr 01, 2011 5:19 pm
TinPan wrote:Not sure which one should be selected
Microphone
CD player
Line in
SPDIF in
Aux
Stereo Mix
Wave
For recording streaming Internet radio you should select "Stereo Mix" (as described here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel )
TinPan
Post by TinPan » Fri Apr 01, 2011 7:20 pm
All is fixed, reverb too. Thanks for all your help Steve!
cowboy
Post by cowboy » Thu Apr 07, 2011 3:57 pm
Seems like this might be a good place to bring this up.
I was chasing a ghost, some of the issues here....... when it really is a volume problem ???
I've checked all my setting via the various Realtek panels etc
And everything is OK, I can listen to things on the web fine or play mp3's thru a player
and volume is normal.
When I record on Audacity, I can see the input bars moving, but when playing back it is
so low that I couldn't hear it..... so there is quite a difference.
Once I discovered this I cranked everything up to the max, now I can here when in playback on Audacity, but
of course when playing other things it is extremly loud.
Any ideas on what the problem is. I'm running 1.2.6
Resolved :
after doing a search I found the issue via the wiki info in this post
http://forum.audacityteam.org/viewtopic ... me#p135923
p.s. a
