Hi guys
where do the saved mp3s go so i can listen to them again
saved files
curiousgeorge
Re: saved files
To create an MP3 from an Audacity Project you must "Export" (from the "File" menu).
Audacity does not support MP3 encoding as standard (due to licensing restrictions), so Exporting as MP3 requires LAME to be installed.
http://audacityteam.org/help/faq?s=install&i=lame-mp3
If you're unsure of the difference between "Save" and "Export", or what exactly an "Audacity Project" is, then see here: http://manual.audacityteam.org/man/Audacity_Projects
curiousgeorge
Re: saved files
ok got it thankyou
