Seeking a codec/filter that will help me mimic radio chatter
Bahger
Post by Bahger » Thu Mar 17, 2011 3:42 am
Thanks for the great product. I'm going to be making sound files for a flight simulator and want the audio output to sound filtered/distorted in the manner of military radio comms. There are so many codecs available for Audacity, can anyone recommend one? Or might such a thing already be incorporated into the Audacity Beta for Windows Vista?
Many thanks in anticipation.
Re: Seeking a codec/filter that will help me mimic radio cha
Post by kozikowski » Thu Mar 17, 2011 6:29 am
You can start by applying the equalizer tool in the "telephone" setting: drop everything below 300 and above 3000. There may even be a pre-baked filter that does this.
Then apply Effect > Leveler about three times at maximum compression.
Bahger
Post by Bahger » Fri Mar 18, 2011 7:30 am
Koz, your suggestion was very helpful. However, I cannot find a "Telephone" settting in the Effects/Equalizer tool, can you advise? Many thanks.
Post by kozikowski » Fri Mar 18, 2011 10:32 am
You have to build it. Run Effect > Equalization. The blue line in the middle is a rubber band and you can push it around with your mouse. Make it look like this...
Picture 1.png (50.26 KiB) Viewed 1599 times
In Audacity 1.3, you can save it for use later.
Bahger
Post by Bahger » Fri Mar 18, 2011 3:05 pm
Perfect! Thanks a lot, Koz. It'll get a lot of use.
