[live sound] putting Audacity between the mics and mixer
Edgar
Forum Crew
Post by Edgar » Fri Mar 11, 2011 5:04 pm
I split this off from http://forum.audacityteam.org/viewtopic ... 19&t=53826
J,R,D, Ltd wrote:
Edgar wrote: You are really jumping in the deep end
Well, I like challenges, especially when it has to do with electronics.
I figured out a way to connect my computer between the mics and the mixer but it would require me making some custom cables.(Which isn't a problem for me) As long as I can edit the tracks in Audacity I don't have a problem with using other software to do the actual recording as long as it is stable.
Your right, this is getting off-topic, I guess this would go best under Recording Equipment, or Techniques?
There are splitters for XLR but unless you spend big bugs on electronic isolation you are asking for trouble. Making your own cables will likely yield sub-optimal results. If any of your mics require phantom power this is especially likely to cause problems as the phantom power ends up returning down both legs of the split and sending phantom into the inputs of a computer sound card might be problematical--YMMV.
look at:
http://www.newegg.com/Product/Product.a ... 004V-000C7 $190 but is NOT isolated.
Look at this great article from Whirlwind which explains why an "active" splitter is needed:
http://whirlwindusa.com/support/tech-ar ... splitters/
and at $700 what you really need:
http://compare.ebay.com/like/3502322850 ... 602_304662
I am not recommending you purchase from any specific vendor--these are just examples of available products!
Re: [live sound] putting Audacity between the mics and mixer
Post by steve » Sat Mar 12, 2011 8:04 pm
Edgar wrote:I figured out a way to connect my computer between the mics and the mixe
Many mixing desks have "Direct Out" connectors.
If a recorder is connected to the direct out connectors, the the signal path is:
Microphone -> Mic Pre-amp in Mixer.
Mic Pre-amp in mixer -> Mixer channels controls
AND
Mic Pre-amp in mixer -> Direct Out -> Line input of recorder.
Electronics in the mixing desk should ensure that the Direct Out is suitably isolated from the mixer channel.
Edgar
Forum Crew
Post by Edgar » Sat Mar 12, 2011 9:46 pm
steve wrote:
not Edgar but J, R, D, Ltd wrote:I figured out a way to connect my computer between the mics and the mixe
Hi Steve!
First, your quote is attributed to me when in was made by J, R, D, Ltd--not that I care, just to keep the record straight <grin>!
I do disagree that "many" mixers have direct out; IMHO, only the higher-end pro desks have per-channel direct out. I can think of no consumer-grade mixer with such. I am willing to be persuaded by some examples!
Post by steve » Sun Mar 13, 2011 11:19 am
Edgar wrote: your quote is attributed to me when in was made by J, R, D, Ltd
Apologies for that. The forum software often messes up attribution with nested quotes and I didn't notice that it had done so.
Edgar wrote:I do disagree that "many" mixers have direct out; IMHO, only the higher-end pro desks have per-channel direct out. I can think of no consumer-grade mixer with such. I am willing to be persuaded by some examples!
I agree that you're unlikely to get such features on the very small mixers, but for mid-range home studio mixers:
Behringer: Most of the (older) Behringer desks have direct out on the microphone channels (I've not checked their most recent mixers), though in some cases these are "channel out" rather than "direct out" (they still call them "direct out" but on some models these outputs are pre-mix, post fader).
Phonic: Some of the Phonic mixers have direct outputs (example UM Helix 24 - I've not looked at the smaller Helix mixers).
Mackie 802 VLZ3 : Combined Insert/Direct Out on channels 1 and 2
If only 1 or 2 channel recording is required, many consumer grade desks have a couple of AUX outputs that could be used for pre-mix recording, and some have switch-able "ALT" outputs that could provide 1 or 2 additional recording channels.
Edgar
Forum Crew
Post by Edgar » Sun Mar 13, 2011 5:17 pm
steve wrote: I agree that you're unlikely to get such features on the very small mixers, but for mid-range home studio mixers:
Behringer: [...]
Phonic: [...]
Mackie [...]
Good info, I am familiar with Behringer and Mackie. I use the AUX outs myself as you suggest but this limits most consumer (and even mid-range pro) grade to a max of 4. Obviously, without compiling in ASIO support, Audacity can only handle 2 channels of input so this would work.
Now, the tricky part is that the OP is looking to record 16 channels with Audacity and ASIO. I personally think that whatever sound pod the OP eventually uses will come with recording software which will be more suitable than Audacity for this task. I would save each track individually in the supplied software then import them into Audacity for post-production. I did this with an 8 channel studio CD I recently produced but mixed down to stereo in the supplied software before importing into Audacity.
J,R,D, Ltd
Post by J,R,D, Ltd » Mon Mar 14, 2011 4:28 am
Thanks for the info Edgar and Steve! I will post with more detail later, in the mean time here is the manual to our mixer. http://www.mediafire.com/download.php?s6886bd0dv7gc2j We have a Yamaha MG32/14FX.
Edgar
Forum Crew
Post by Edgar » Mon Mar 14, 2011 5:13 pm
Very nice pro-grade mixer--no per-channel direct out. As it has 6 AUX outs and 2 (usable for your case) groups you could use these as 8 pass-thrus but would lose them for other uses. You can build your own isolated Ys but I would bite the bullet and buy, if it were up to me and I had the spare $$s <grin>!
Post by steve » Mon Mar 14, 2011 5:43 pm
As long as your recording inputs have "Line" inputs with a reasonably high impedance (~ 20 k or more), then you could connect the "Channel Inserts" to a half-normalized patchbay. To do this you would need an "Insert cable" ("Y" cable) for each channel.
Example Insert Cable: http://www.thomann.de/fr/cordial_cfy_3_vpp.htm
Half-Normalized patchbays are available fairly inexpensively from Behringer or Neutrik.
This method is not suitable if the recorder has only low impedance microphone inputs (~ 600 Ohm)
J,R,D, Ltd
Post by J,R,D, Ltd » Fri Mar 18, 2011 4:07 am
Edgar wrote:Very nice pro-grade mixer--no per-channel direct out. As it has 6 AUX outs and 2 (usable for your case) groups you could use these as 8 pass-thrus but would lose them for other uses. You can build your own isolated Ys but I would bite the bullet and buy, if it were up to me and I had the spare $$s <grin>!
Yes, it is a very nice mixer.
The 6 AUX outs are actually four + two because the two (5 and 6) are switched between being AUX out and Effect on a per channel basis. Why would only 2 of the 4 groups be usable for my case?
Do you have a schematic for an Isolated Y? I did a quick Google search but couldn't find one. Would that be the same as what the Manual calls an insertion cable?
steve wrote:As long as your recording inputs have "Line" inputs with a reasonably high impedance (~ 20 k or more), then you could connect the "Channel Inserts" to a half-normalized patchbay. To do this you would need an "Insert cable" ("Y" cable) for each channel.
I actually drew a schematic for an idea I had using the Insert I/O Jacks:
Schematic presenting two cabling ides.
quarter-inchx2 to eighth-inch cable diagram.PNG (7.1 KiB) Viewed 4918 times
I figured that if I just used a mono plug it would cut off the signal from the mixer so there would be no output on that channel and that would kinda defeat the purpose of the sound system.
Then I figured I could use a stereo plug and short the Tip and Ring terminals together in each Insert I/O Jack and then put two mixer channels on one stereo channel as is illustrated in the schematic above. I actually built a board out of stuff I had that allowed me to essentially have this setup for testing two channels and it worked.
Now that schematic was originally made when I was planning on making an el-cheapo but I found that I didn't have as many identical sound cards as I thought I did. I also saw a post on here someone made about making a USB sound device for much less than the commercial devices, don't remember where it was now, unfortunately he didn't post specifics. I am willing and able to assemble electronics if I can save money by doing so but I also believe in buying the right tool for the job as long as it is not too expensive.
Well that is enough for one night, it is getting late here.
Edgar
Forum Crew
Post by Edgar » Fri Mar 18, 2011 5:27 am
J,R,D, Ltd wrote:
Edgar wrote:As it has 6 AUX outs and 2 (usable for your case) groups you could use these as 8 pass-thrus but would lose them for other uses. You can build your own isolated Ys
in re. 4 + 2 that is why I said you would lose them for other uses--they are either AUX or Effects--so not more reverb on the vocals! As for the Groups, as per the manual the assign buttons are ganged 1/2 & 3/4 and (as opposed to the norm) are not split by the pan--so pressing 1/2 assigns to both 1 & 2 (I may have mis-read the manual).
My boss built his own "transformer isolated splitters" (that is what you need to Google) many years ago and we still use them for on-stage monitor mixing. He also just bought a second set but time is money and he's getting well up into his 70's now and probably has less fund soldering than mixing!
As for your schematic, in the 60's I built huge computers for universities using nand gates, clock chips, diode arrays etc.; we silk screened our own boards and had a soldering wave tank; but...I think I was in the 60's as I do not recall them! I have a lot of hard won experience as a sound tech but my ET days are more than 50 years ago. I will have to pass!
