TROUBLE DOWNLOADING LAME .exe FILE
jkligman
Post by jkligman » Mon Mar 07, 2011 8:14 pm
I just downloaded Audacity onto my school computer (Windows XP). When I click on "Lame v3.98.3 for Audacity on Windows.exe" on the download page, I got an error message saying that the setup files were corrupt. Now, I get a weird antivirus message about Basine-C (a trojan). Is there any other way to download the LAME mP3 converter file?
Re: TROUBLE DOWNLOADING LAME .exe FILE
Post by steve » Tue Mar 08, 2011 12:07 am
jkligman wrote: I get a weird antivirus message about Basine-C (a trojan).
Sort that out first.
Your computer anti-virus program is fully up to date?
Run a full system scan - the one that you have to leave running overnight.
jkligman
Post by jkligman » Wed Mar 09, 2011 2:02 pm
Steve,
Thanks for your quick reply. My virus definitions are up to date, and a full scan had (and has) been done. No problems to report.
I tried again to download the LAME plug-in, and I'm back to the original error message. I get as far as choosing to run the .exe file, and then I get this message: "The setup files are corrupted. Please obtain a copy of the new program." New program?
I'm trying to download using Internet Explorer. Should I use Firefox, instead, perhaps?
gbreynol
Post by gbreynol » Wed Mar 09, 2011 4:07 pm
My firewall blocks the file as well and shows it as a Basine-C (Trojan). Interesting.
Post by steve » Wed Mar 09, 2011 11:26 pm
As per the instruction: http://audacityteam.org/help/faq?s=install&i=lame-mp3
I've just downloaded (with Firefox) Lame_v3.98.3_for_Audacity_on_Windows.exe from here: http://lame.buanzo.com.ar/
MD5 : 3de12862d13635e908b4aca6c323762b
SHA1 : aa6baa84104bfd4739e1d961dc5bdf928398c490
SHA256: 005a3c0aff3d6a7d87e2074a4f1b6ab46e1557b952a0be360e50433701e7cd94
Virus check results here: http://www.virustotal.com/file-scan/rep ... 1299712452
jkligman
Post by jkligman » Mon Mar 28, 2011 2:31 pm
Steve,
Well, I tried it again, and I still get the corrupted file message. Is there no other way to download this?
--Jessica
Post by steve » Mon Mar 28, 2011 7:02 pm
What anti-virus and firewall programs do you have running?
jkligman
Post by jkligman » Mon Apr 04, 2011 7:02 pm
Symantec Endpoint Protection and Webroot Spy Sweeper Enterprise. Does that also cover the firewall software?
It all worked on my other school's computer. I went ahead and emailed to myself the LAME folder of files from that computer and saved them onto this computer, but there was nothing of substance in the folder that will make it all work.
Post by steve » Mon Apr 04, 2011 10:32 pm
jkligman wrote:It all worked on my other school's computer
If you are trying to download on a school computer via their internet connection then there is almost certainly a firewall between the computer and the Internet. Schools frequently have very restrictive Internet filtering and it is very likely that a school network connection would prevent you from downloading Lame. The school network security is also likely to rip out Lame from e-mail attachments. If you want to install it on a school computer you will probably need to speak to the school's IT person/department.
jkligman
Post by jkligman » Wed Apr 06, 2011 6:52 pm
Okay, then, I'll do that! Thanks for your help.
