Which one is .dmg?
Which one is .dmg?
Brand new user. I just downloaded audacity on my mac and it asked me to create a folder in applications called audacity which i did. Next I was supposed to move the downloaded files (except for .dmg) in the folder. My problem is I dont know which one of the six options is the .dmg.
Re: Which one is .dmg?
You can Control-Click on the file > Get INFO and it should tell you what the long-form filename is. You can also get the finder to show you all the file extensions.
Desktop > Finder > Preferences > Advances > Show All File Extensions.
