vu meters
billw58
Re: vu meters
Can you actually close the VU meter window in 1.2.x after you've floated it?
Anyway, in 1.2.x choose View > Dock Meter Toolbar.
In 1.3.2, choose View > Toolbars > Meter Toolbar.
-- Bill
-- Bill
Re: vu meters
You should probably be using Audacity 1.3.12 from here:
Audacity 1.2 is no longer supported particularly on newer Macs. If you have odd behavior, the oddness is going to get worse.
You can install both versions safely, but only use one at a time. Audacity 1.3 Projects will not open in 1.2.
