Get rid of white noise in background?
southboundpachyderm1
Post by southboundpachyderm1 » Thu Mar 03, 2011 3:02 am
Is there a way to get rid of a very soft white noise in the background of guitar or bass recordings? Its from the recording, which was not done in audacity, but I was hoping audacity might have some type of tool to get rid of it. thanks
Trebor
Re: Get rid of white noise in background?
Post by Trebor » Thu Mar 03, 2011 3:30 am
Audacity's noise reduction should help, (set the noise reduction as low as possible, typically around 10dB)
http://manual.audacityteam.org/index.ph ... se_Removal
http://www.youtube.com/watch?v=mlKX6p85R2M
In a bass recording you may also be able to cut back the high frequencies in Audacity's equalizer, which would reduce the hiss without affecting the bass too much.
