Output on headphones
jlgoetz
Post by jlgoetz » Tue Mar 01, 2011 7:38 pm
The help on this forum has been much appreciated! QUESTION: I can hear through my headphones during the recording, (mono track/mic only), but on playback, I cannot. Using the Mini Box 2 preamp...records fine, but no playback through the headphones...
justinburnett
Re: Output on headphones
Post by justinburnett » Tue Mar 01, 2011 7:47 pm
My guess is that in your input and output device setting are different. This would mean that the input is set as the Mini Box 2, but the output may still be set as your computer. You can test the theory by playing back the track and plugging the headphones into the computer. To correct this, go to Edit ----> Preferences ----> Audio I/O and make sure that your output is set to whichever you prefer.
Take care
-Justin-
jlgoetz
Post by jlgoetz » Wed Mar 02, 2011 1:49 am
Thank you, Justin...but I don't see an Audio I/O under Preferences...
justinburnett
Post by justinburnett » Wed Mar 02, 2011 3:21 am
Hi
Sometimes, especially if you're using a slightly lower monitor resolution, it won't show all the tabs at once, and you have to kind of scroll sideways to see them all. That one used to confuse me and irritate me for ages. Anyhow, here's what should be there:
Your devices will of course be different, but that's the idea. Look for a tiny arrow/triangle at the edge of the tabs, to shift it over the the I/O tab. Let me know if it doesn't turn up.
Take care
-Justin-
jlgoetz
Re: Output on headphones - I/O preferences
Post by jlgoetz » Wed Mar 16, 2011 10:23 pm
Thank you, Justin, but am still not selecting a choice that works for output...yes the playback works through the speakers, but not the headphones, even after selecting and testing each and every preference in Audio preferences for output. What do I want to see to select? Nothing selected sends the sound through the MiniBox 2 and through the headphones on playback. I've been working with a computer guy in the mean time and we have made no progress. Thank you for your patience...but not progress yet.
jlgoetz
Post by jlgoetz » Tue Mar 29, 2011 2:17 am
This was resolved with installation of additional Windows 7 drivers...finally! Jennifer
