Mic works with Skype but not Audacity, using Win7
rhst1
Post by rhst1 » Mon Feb 28, 2011 10:02 pm
Have tried mic input with both 1.2 and 1.3 Audacity and no sound is recorded. Same equipment works fine with Skype. Any ideas on what is wrong, how to fix? Am using Windows 7.
Thanks.
Re: Mic works with Skype but not Audacity, using Win7
Post by steve » Mon Feb 28, 2011 10:20 pm
Ensure that Skype is completely shut down (not even open in the background) before you open Audacity.
Skype tends to take over the computer sound system making it difficult or impossible for Audacity to run correctly.
rhst1
Post by rhst1 » Mon Feb 28, 2011 10:30 pm
Thanks Steve. I closed Skype, but still nothing in Audacity.
Post by steve » Mon Feb 28, 2011 10:47 pm
For Wind 7, forget about Audacity 1.2.x, the recommended version is Audacity 1.3.12.
You can check the exact version number in "Help menu > About Audacity"
If necessary, download Audacity 1.3.12 from here: http://audacityteam.org/download/
What sort of microphone are you using? Does it plug into your sound card? Is it a USB microphone?
rhst1
Post by rhst1 » Tue Mar 01, 2011 2:14 am
I downloaded and installed the latest version of Audacity before posting. The mic plugs into the mic jack on the computer - a dual core HP laptop.
Post by steve » Tue Mar 01, 2011 2:19 am
In Audacity go to "Edit menu > Preferences > Devices" and ensure that your sound card is selected for recording and playback.
In the sound card recording preferences (right click on the sound card icon near the Desktop time date) set the microphone as the default recording input - you can also set the "quality" setting here - 16 bit 44100 Hz mono is recommended (if available), and set the recording level.
rhst1
Post by rhst1 » Tue Mar 01, 2011 7:34 pm
Thanks for your persistence, but having tried all the recent suggestions, I'm sorry to report no success.
Post by steve » Tue Mar 01, 2011 11:04 pm
So what is happening when you try to record?
rhst1
Post by rhst1 » Wed Mar 02, 2011 8:43 pm
Just a flat blue line.
Post by steve » Thu Mar 03, 2011 12:06 am
What are your settings in Audacity "Edit menu > Preferences > Devices"?
What are your Recording settings in the Windows Control Panel? http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
