How to use the Wah effect from audacity on other programs?
i really like the wah effect i get when using audacity. im wondering which of the files is the wah under the plugins? thanks
Re: How to use the Wah effect from audacity on other program
It may not be a classic plugin. I believe all the effects above the dotted line are built into the program. All the ones below that line are movable add-ons.
aww man. ok thanks anyway
You can always be doing something in a tracker or something...then record the song into audacity with the "mix in" then apply it!
