Here are the Build and Debug logs.
It looks like it worked!!
You're right, and your welcome. I couldn't have done it without your help, thanks.Edgar wrote:I feel that we have both put a lot of hard work into this and I want to thank you for sticking with the project! Doesn't it feel really nice to succeed in the face of lots of difficulty--well done!
Now, if you would not mind, as the original poster you may edit the title of this post; I think it would be nice if you were to include ASIO somehow in the title and also note that it is "solved" maybe something vaguely like:
[both solved] Having a lot of trouble compiling Audacity from SVN & getting ASIO to compile in
That way others who stumble on the thread via search will not only know we dealt with two problems but that you eventually solved them both.
Thanks Steve!steve wrote:Congratulations on your success J,R,D.
I've renamed this thread to make it more visible, but feel free to rename it again if you think the title is wrong.
No thanks needed--you cannot imagine the tremendous amount of help I have gotten from others on this forum!J,R,D, Ltd wrote:I couldn't have done it without your help, thanks.I love the feeling of accomplishing things, especially difficult things like this.
Now, What files would I need to transfer to my recording PC should I choose to use Audacity with ASIO support? I don't have to build Audacity on the PC I want to use it on right?
