Improving quality audio from a video.
Daniel_Figueiredo
Hello.
I like to improve the qualitity of the soud of a video But as I'm editing the audio sound quality of the video only gets worse.
I'm newbie on audacity and I'm a little bit newbie in the world of sound.
Can you see the video at here : http://rapidshare.com/files/449639572/Componentes.zip
Anyone can give me some tips or help.
Re: Improving quality audio from a video.
I can only watch/listen to the first 3 seconds of your video, then it goes black and mute.
In those first 3 seconds of audio there's a lot of noise, which is louder than your voice. You could try the noise removal effect, but your show seems to be pretty much damaged to make it sound good...
Any chance you can re-record it? If so I think you should try to improve the recording quality of the show before trying post-processing.
How did you record it? There seems to be a serious electromagnetic interference near the recording equipment.
Which audacity version and operating system are you on? What recording equipment did you use? Were you close to any transformer, fluorescent light bulb, or any other possible electromagnetic source?
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
200 frames per second is excessive for a video recording of computer screen:
if the only thing moving on the screen is the cursor then ~20 frames per second may be sufficient ...
this high frame rate means your video file is many times larger than it needs to be.
I think the only solution is to re-record the commentary (over dub).
Daniel_Figueiredo
I can re-record it is not easy synchronize the soun in the video.Any chance you can re-record it?
I record it with the volume of micro in the sofware to record the screen and in the Sound Definitions on maximum ( because my micro record my microphone records the sound volume too low for my taste, if I did not put the volume too high for the sound quality.)How did you record it?
I use Audacity 1.2.6 for windows.Which audacity version and operating system are you on?
I use the internal micro of my laptop.What recording equipment did you use?
Of couse that to make the show minimally confortable I have to talk with his mouth away.
I have nothing.Were you close to any transformer, fluorescent light bulb, or any other possible electromagnetic source?
Nor had the power transformer connected to the PC computer.
The buzzing could be an artefact caused by the computer unable to cope with the astronomical frame rate (200fps).
[If the buzzing is present when you record your voice using audacity, no video software running, then the above hypothesis can be excluded]
All I saw on the video was a 3 second recording of a computer screen.
Here are the properties of a screen recording video I made …
"Audacity the movie" can be downloaded from here, (15 seconds, 57Mb AVI format).
Daniel_Figueiredo
Use the program in the link http://www.dvdvideosoft.com/products/dv ... verter.htm to record the audio to the PC. Is this program that I use to record the audio from the videos.
You should be able to adjust the frame rate, screen resolution, audio sample rate etc, in the settings of your screen capture program.
The trade off is quality against file size: use the lowest frame rate, resolution etc that you can bear to keep the file size down,
otherwise a 10 second video will take 10 minutes to download.
Daniel_Figueiredo
I got remove some noise at the record.
You can try help to imoproving more the qualitity of the Record.
Liste the Reocrd at http://db.tt/z7lzofM
That sounds like far too much noise reduction had been applied. (however the original audio, before you applied noise reduction, may be usable).Daniel_Figueiredo wrote:I got remove some noise at the record.
You may have applied the noise reduction incorrectly: it is a two step process where you first select part of the audio which should be silent, (no speech), as a noise profile. Then you select “noise reduction” from the “Effect” menu again to remove this noise profile from the selected speech audio.
http://manual.audacityteam.org/index.ph ... se_Removal
http://www.youtube.com/watch?v=mlKX6p85R2M
Daniel_Figueiredo
I do the 2 stesps but I don't do the 2nd step rightly.
I do the 2nd step to all Record.
