Hi. I installed SilenceMarker.ny using the info found in this wiki: http://wiki.audacityteam.org/index.php? ... ate_tracks
When I select the entire waveform (or even just a small section of it) and click Analyze-Silence Finder, nothing happens. Nada. Zilch. The menu item is not greyed out. I am running Audacity 1.2.5 on Mac OX 10.6.6.
Is anyone using SIlence Finder successfully with Audacity on a Mac?
Silence Finder - Nothing Happens
FenderBender
Re: Silence Finder - Nothing Happens
Actually, your problem may be a bit more straightforward than that. Audacity 1.2 is not supported under Snow Leopard. Get Audacity 1.3.12 from here:
You can install both, but only use one at a time. Audacity 1.3 Projects will not open in 1.2.
