Initialization Error
t0xikc0mputer
Post by t0xikc0mputer » Mon Feb 21, 2011 1:43 pm
Hello all,
I have the Audacity Portable version. I was trying to install some Anares VST plug-ins in the "F:PortableAppsAudacityPortableAppaudacityplug-ins folder" but when I do, there is an error that comes up twice consecutively, a window pops up that looks as if it's installing/scanning something, then the error pops up again. (I have attached a snapshot of the error below) Anything I am doing wrong that I could fix, please let me know. Also, I am pretty sure that this error came up when I had installed the VST effects Bridge package from the Audacity website to the plug-ins folder.
Thanks,
t0xik
This is a snapshot of the error message.
Re: Initialization Error
Post by steve » Mon Feb 21, 2011 2:22 pm
For VST support, use Audacity 1.3.12 - it has much better VST support than the old 1.2 version.
If you use Audacity 1.3.12 you should not use the VST bridge.
VST effects may require administrative privileges. This is not something that is controlled by Audacity.
