sound distortion
dochiphop
sound distortion
Post by dochiphop » Mon Feb 21, 2011 3:09 am
i use audacity 1.2.6 with an ION TTUSB with a Technics cartridge with windows xp. I am getting distortion and cant figure out how to fix the problem. Nothing i have read online has worked for me. Some of the potential solutions i read about ask you to use features in the effects tab. However, my effects options are all grayed out so i have none of those options currently available to me. How do i get all of those options in the effects tab to be available to me? And more importantly, how do i fix this distortion/ clipping problem?
Thanks,
Mark
Re: sound distortion
Post by kozikowski » Mon Feb 21, 2011 3:14 am
In Audacity 1.2, you had to select some audio (or all of it) to get the Effects to work. Koz
dochiphop
Post by dochiphop » Mon Feb 21, 2011 3:25 am
Koz,
thanks for the quick reply. So what do you suggest i do to try to eliminate distortion and clipping?
Post by kozikowski » Mon Feb 21, 2011 4:44 am
That was just the easy answer. Yes, you should be solving the problems at the beginning.
There's no shortage of problems with ION turntables. They're not designed to be left to your grandson. They're designed to play the last record and then fall to dust.
http://forum.audacityteam.org/viewtopic ... ON#p128624
waxcylinder
Post by waxcylinder » Mon Feb 21, 2011 11:44 am
See this article in the Wiki: http://wiki.audacityteam.org/wiki/USB_turntables
I would recommend you to upgrade to the latest Audacity 1.3.12 (and look out for 1.3.1.3 which is due out soon) - you can get it from here: http://audacityteam.org/download/
clothbottom1
Post by clothbottom1 » Tue Feb 22, 2011 8:42 am
Thanks for the article waxcylinder. I've some problem with the 1.2 version of audacity and I never know how can I upgrade it to some latest versions of it. your article in this context is really helpful .Thanks
Taylor Ringo
Post by Taylor Ringo » Sun Feb 27, 2011 8:37 pm
I am new to AudaCity Im using it because the creator of DS Game Maker told me this a good music making engine for DS Game Maker, I want to know if Audacity can distort voices, y`know high to low... like Fred...
Post by kozikowski » Sun Feb 27, 2011 9:00 pm
Can you point to a sound clip on-line somewhere that has the voice you want to create? I have no idea who Fred is.
You can use Effect > Leveler at the various different settings to create straight clipping voice distortion. Many other vocal effects use Vocoder or AutoTune effects. It depends on what you want.
