recording problems
Zealousman
recording problems
Post by Zealousman » Sun Feb 20, 2011 6:22 pm
I cannot get anything to record, from my new microphone, to the Audacity 1.3 software!!! Can anyone, at all, suggest any solution(s)? -Geoffrey :x
Re: recording problems
Post by kozikowski » Sun Feb 20, 2011 7:54 pm
Sure, but you need to fill in all the holes between your lips and Audacity. Which microphone, how is it connected, which computer, which operating system, which Audacity?
Zealousman
Post by Zealousman » Mon Feb 21, 2011 2:42 pm
Dear Kozikowski ! --Thank you very much, for your time to assist me here!! I really appreciate it.
I have a Logitech USB microphone, connected by USB;; I am using a Dell Intel Dimension 2400 computer, using Microsoft
XP, home edition software. Finally, it is Audacity 1.3 Beta software.
Perhaps I just do not have enough Ram, in this old boat! I checked the microphone twice!! It is working with it's own play-back test. :?
Thanks again! -Geoff
Trebor
Post by Trebor » Mon Feb 21, 2011 3:20 pm
Zealousman wrote: I have a Logitech USB microphone, connected by USB;; I am using a Dell Intel Dimension 2400 computer, using Microsoft XP
You should select the USB microphone in windows recording devices as the (default) device you want to record from ...
Windows XP mixer- set default recording device to USB.png (35.49 KiB) Viewed 828 times
http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
I was about to suggest that you disable the computer's in-built microphone in the windows mixer, but apparently the Dell Dimension 2400 doesn't have one.
Manual for Logitech USB Desktop Microphone, page 3.png (18.28 KiB) Viewed 827 times
http://logitech-en-amr.custhelp.com/app ... hxN2Juaw==
