Remove Kick Drum from Dance--Trance mp3s
xrx.black
Post by xrx.black » Sun Feb 20, 2011 5:52 pm
Hi,
I'm new to Audacity and sound editing and I don't know sound editing terms and phrases.
I want to remove the kick drum from dance/trance mp3s.
I searched the web and this short post was all I could find:
http://uk.answers.yahoo.com/question/in ... 734AAHmOYJ
What do they mean when they say "First insert either a 'low shelf' from a parametric eq OR insert a hi pass filter." and "notch pass filter."
Is their approach correct? If so, which is better, 'low shelf', 'hi pass', or 'notch pass'?
Again, I have no idea what they're talking about. I've only installed Audacity and LAME.
Please help, thanks.
Trebor
Re: Remove Kick Drum from Dance--Trance mp3s
Post by Trebor » Sun Feb 20, 2011 6:51 pm
xrx.black wrote: I want to remove the kick drum from dance/trance mp3s.
Senior forum staff member Steve has made a free "popmute" plug-in for Audacity which will attenuate the kick without altering the equalisation, (which the techniques you listed above would do). A before-after example is attached ...
before-after kick drum attenuated with Steves 'popmute' plug-in -.mp3
(357.14 KiB) Downloaded 302 times
Trebor
Post by Trebor » Fri Feb 25, 2011 3:10 pm
Apparently my suggestion of Steve's "popmute" plug-in has done the trick ... http://forum.audacityteam.org/viewtopic ... 65#p130365
