If anyone can help I'd be so greatful
Imported audio playback problems
I've just started using audacity to slow down songs as a way of learning them on guitar. I'm having trouble playing them back though. It just plays a horrible noise for about a second instead of playing back the real audio. There is no problem with the audio files as I've tried them in other programmes and they work perfectly.
waxcylinder
Re: Imported audio playback problems
You are almost certainly trying to import a file type that Audacity does not support . Audacity Supports WAV, MP3, OGG and FLAC & MP2 in 1.3.
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
Thanks a lot!!!!
