merging .au files
This section is now closed
Lievent
merging .au files
Post by Lievent » Mon Feb 14, 2011 2:35 pm
Hello,
I'm new here,
last night I did a recording, at the end (luckily) of the recording,
my mac crashed...
I have all the 5687 .au files,
how can I easily merge them (without opening each single one of them and copy past them in a new file)
thx!
Re: merging .au files
Post by kozikowski » Mon Feb 14, 2011 3:36 pm
Audacity 1.3.12 has very nice crash recovery tools -- less so in 1.2.
Crash Recovery
http://audacityteam.org/wiki/index.php? ... shRecovery
They go Left, Right, Left, Right and the first two are picture files -- if the process got that far.
Modern Macs do not support Audacity 1.2. You can get Audacity 1.3.12 from here...
You can install both versions, but only use one at a time. Audacity 1.3 Projects will not open in 1.2
If you use Lame and FFMpeg, get those from the same place. Don't use older ones or ones from other web sites.
