robsonsilvar
Post
by robsonsilvar » Mon Feb 14, 2011 1:00 am
Hello all,
I was using Audacity 1.3.x (Beta) when i have moved the mouse and the timeline has gotten a negative number, but a very low negative number. So i couldn´t goback to timeline zero, so i saved the project e closed the program.
Now, when i open the project, the Audacity get loading forever e my cpu get to working in 100% e lock the pc and moreover the project doesn´t open. i think the Audacity´s project is locking because the timeline is a very low negative number. I tried open the project by notepad to check the starts configuration, i see that a xml structure, but there are many things there. Can Someone help me??? I spent 5 hours in this project and i can´t open it more
Thanks!
- Site Admin
Post
by steve » Mon Feb 14, 2011 1:10 am
Could you attach the .AUP file for us to look at. (see "Upload" tab below the message compose box)
robsonsilvar
Post
by robsonsilvar » Mon Feb 14, 2011 11:11 am
Hello steve,
I am in my job now, when i arrived in my home i will attach the .AUP file.
thanks
robsonsilvar
Post
by robsonsilvar » Mon Feb 14, 2011 10:58 pm
Hello steve,
Here is the .AUP file. I hope you can help me
thanks
- zoio de lula.aup
- (64.33 KiB) Downloaded 73 times
- Site Admin
Post
by steve » Tue Feb 15, 2011 2:53 am
No guarantees, but let's have a go:
- Make a new folder
- Copy the folder "zoio de lula_data" into the new folder
- Download the attached file and put it in the new folder
- See if this modified project will open
- If it does open, see if it will play
- zoio de lula.aup
- modified AUP file
robsonsilvar
Post
by robsonsilvar » Wed Feb 16, 2011 1:08 am
Hi steve!
it worked!!!!
thanks a lot!!!
One more think. the output audio is low (i think my mic is not very well), do you know how can i adjust the program to get higher?
thanks again!
- Site Admin
Post
by steve » Wed Feb 16, 2011 1:33 am
One of the things that I changed was some accented characters in one of the track names.
Audacity 1.3.12 does not fully support non-English characters, so for the present it is best to stick with conventional letters (a-z, A-Z) numbers, hyphen, underscore and space. These are all "safe" characters. I can't be certain if that was the actual problem as I also made a few other minor alterations to set display parameters within a very "normal" range.
Exact details for adjusting the recording level depends on the type of microphone, sound card and operating system, but usually there is an icon in the bottom right corner of the Desktop (near the Time/Date) that allows you to adjust the recording level.
robsonsilvar
Post
by robsonsilvar » Fri Feb 18, 2011 12:46 am
ok,
thanks a lot!
