Length of recorded time changes
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
FirstLoveMusical
Each time I bring a recording backing into Audacity the overall length of time of the recording changes. It's about three tenths of a second, but if you do this several times you continue to add time to the recording. Any suggestions, or is this an inherent fault of the program? I've included three printscreens of the same file showing the lenght of time changing.
- Attachments
- First Recorded Time
- ScreenShot034.jpg (83.27 KiB) Viewed 643 times
- Second Recorded Time
- ScreenShot035.jpg (85.78 KiB) Viewed 641 times
- Third Recorded Time
- ScreenShot036.jpg (110.08 KiB) Viewed 641 times
Re: Length of recorded time changes
That looks like a lot less than 0.3 seconds difference.
If you look at the times in the "Selection Toolbar" at the bottom of the main Audacity window (set it to hh:mm:ss +milliseconds) it will show the times to the nearest millisecond.
What sort of file are you importing? MP3?
