Windows7 64 bit "High Definition Audio Device"
simonc2
Post by simonc2 » Tue Feb 08, 2011 10:17 am
I'm using a machine with Windows 7 64 bit and the installed Audio device is Microsoft's "High Definition Audio Device". I've installed Audacity 1.3.12 and am trying to record an audio stream from the BBC website. I can hear it through headphones, but can't find a recording device setting so that Audacity can intercept the signal. The only recording devices in the Control Panel Sound dialogue are Microphone (not plugged in) and Line In (not plugged in). I've right clicked in this box and checked "show disabled devices" and basically there aren't any.
I'd be very grateful if anyone could advise if there's a way of configuring this sound card so that Audacity can record.
Many thanks
Re: Windows7 64 bit "High Definition Audio Device"
Post by steve » Tue Feb 08, 2011 8:14 pm
simonc2 wrote: The only recording devices in the Control Panel Sound dialogue are Microphone (not plugged in) and Line In (not plugged in). I've right clicked in this box and checked "show disabled devices" and basically there aren't any.
In that case your sound card does not support "Stereo Mix" recording. Your only remaining option is to use one of the workarounds suggested here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel (see last half of the section in the blue box)
simonc2
Post by simonc2 » Fri Feb 11, 2011 5:41 pm
Thanks for pointing me in the right direction. The workaround proved to be connecting a cable from the Speaker out to the Line in jack which then allows recording using Line in - once I'd realised I had to uncheck Audacity's Software Playthrough option.
