Balancing volume
BelGarion
Balancing volume
Post by BelGarion » Sat Feb 05, 2011 8:52 am
Hello! I'm trying to take audio and balance out the volume on it. Make the loud sounds quieter while making the quieter sounds more louder. I don't see any tools that work based on volume, and Normalize makes *everything* quieter. That doesn't help, some sounds are too quiet while others, like when I mute my mic and it pops, are too loud. How can I fix this audio? Thank you!
waxcylinder
Re: Balancing volume
Post by waxcylinder » Sat Feb 05, 2011 10:23 am
What you're after is called Dynamic Compression or Dynamic Range Compression.
There is a tool for that in Audacity but most folk seem to favour an external too (which can be used as a plugin to Audacity IIRC) called Chris' Compressor (or Chris' Dynamic Compressor) - see http://pdf23ds.net/software/dynamic-compressor/
If you search the forum you should find pleny of posts on Chris' Compressor.
