I've updated all my drivers, using 64 for a 64 system, yet using Cakewalk UA-1G with Audacity crashes Win 7. Any Ideas?
Thanks
Win 7
Re: Win 7
Really? Crashes Windows 7? The computer reboots?
If that's true, you have a bad memory stick (or other hardware component). You can test for this using the Microsoft Memory Diagnostic.
http://oca.microsoft.com/en/windiag.asp
It's quite a production. You have to make a bootable floppy or CD and run the machine from it instead of your hard drive. Run the test multiple times -- although you may not need to. I doubt your machine will make it through the first pass.
Re: Win 7
It could be a combination of problems. Not everybody needs to use High Memory -- the last of the memory sticks. If you hit something that does (Photoshop Gaussian Blur, etc) blammo, there goes the computer.
Do the Microsoft test.
