roxcore USB Turntable new on MAC os X 10,6
Lars Erik Wiklund
Hi have connect the turntable with my new Imac via the USB and everytime I try to record I have " Input device Setting and the project sample rate and cant start. can anyone help me pls. Tks a lot Lars
Re: roxcore USB Turntable new on MAC os X 10,6
You should reset the Audacity Preferences to 44100, 16-bit, Stereo and then restart Audacity. And you should also be in Audacity 1.3.12.
http://forum.audacityteam.org/viewtopic ... 13&t=52707
