Numark TTi
This section is now closed
bigskinny22
Numark TTi
Post by bigskinny22 » Mon Jan 31, 2011 6:04 pm
So the wife bought me a Numark TTi and thought it would be a great way to start converting my vinyl to digital. I used the EZ software that came with it but once recorded the sound lvl is low. I turned the gain knob all the way up but still it is very very very low sound. So, i downloaded Audacity but have no idea how to setup the software to work with my Numark. So, i have already downloaded the latest version for my Mac and just need to know HOW to make the two talk to each other. Im able to drag the recordings over from Itunes after converting them from EZ software just need to know how to up the volume on the recording using Audacity .. simple i think ... but have no idea how to do that.
Re: Numark TTi
Post by kozikowski » Mon Jan 31, 2011 6:52 pm
You should be using the Audacity 1.3.12, not 1.2.
You posted in the Audacity 1.2 forum.
Anyway, open the song and Effect > Amplify > OK.
That's the short form. Most of us don't actually do that because you could run into problems if you need filtering or noise reduction later. While Amplify is open, pick a new Peak of -2 > OK.
Audacity will not Save a sound file. To get a sound file you have to Export one. File > Export.
waxcylinder
Re: Numark TTi
Post by waxcylinder » Mon Jan 31, 2011 7:05 pm
This set of tutorials from the manual should help you: http://manual.audacityteam.org/man/Tuto ... iscs_to_CD
Particularly this one: http://manual.audacityteam.org/man/Reco ... turntables
bigskinny22
Re: Numark TTi
Post by bigskinny22 » Tue Feb 01, 2011 8:23 am
So i think i did this the long way around but tell me how this sounds. So i used EZ converter to convert a track yesterday from vinyl. Once it converted and sent to Itunes i exported it to Audacity and was able to turn the gain up to 20db thus fixing my "sound" problem. Once saved and exported it to my desktop it was in WMV format and wouldnt get pulled into my Itunes (using a MAC). So, my "new" question/problem is can i choose what format to save the track as when im using Audacity? I did download the 1.3.12 yesterday as well ... thanks for the help.
bigskinny22
Re: Numark TTi
Post by bigskinny22 » Tue Feb 01, 2011 8:24 am
kozikowski wrote:You should be using the Audacity 1.3.12, not 1.2.
Whats the "simple" way to filter/noise reduction? I did notice a little background noise once ....
bigskinny22
Re: Numark TTi
Post by bigskinny22 » Tue Feb 01, 2011 8:26 am
waxcylinder wrote:This set of tutorials from the manual should help you: http://manual.audacityteam.org/man/Tuto ... iscs_to_CD
Just read the manual, seems simple enough will try later, thanks.
billw58
Re: Numark TTi
Post by billw58 » Tue Feb 01, 2011 6:04 pm
bigskinny22 wrote:So i think i did this the long way around but tell me how this sounds. So i used EZ converter to convert a track yesterday from vinyl. Once it converted and sent to Itunes i exported it to Audacity and was able to turn the gain up to 20db thus fixing my "sound" problem. Once saved and exported it to my desktop it was in WMV format and wouldnt get pulled into my Itunes (using a MAC). So, my "new" question/problem is can i choose what format to save the track as when im using Audacity? I did download the 1.3.12 yesterday as well ... thanks for the help.
Yes you are doing it the long way around. Forget EZ Audio Converter and do your recording directly in Audacity. Set Audacity to 44100 Hz 16 bit in Quality Preferences http://manual.audacityteam.org/man/Quality_Preferences.
Set up your USB turntable and Audacity following the outline on this page: http://wiki.audacityteam.org/wiki/User: ... ut_devices
As you go through the tutorials, note that you can choose the export format in Audacity. I recommend exported as AIF (best quality), then importing those AIFs into iTunes and letting iTunes do the conversion to MP3 or AAC (your choice). iTunes is much faster at this task than Audacity. I have not idea why you chose WMV as your export format - Audacity should not default to that.
-- Bill
