shortcut
capog
shortcut
Post by capog » Mon Jan 31, 2011 2:32 pm
I'm looking for a shortcut about the function of the effect NORMALIZE.
in fact, it doesn't appear in the list, located in Preference > Keyboard.
Someone kindly explain to me how to obtain this shortcut.
Thank you in advance.
capog
waxcylinder
Re: shortcut
Post by waxcylinder » Mon Jan 31, 2011 3:41 pm
Currently you cannot bind any effects to a keyboard shortcut. This is one of the most popular Feature Requests on the Wiki. Would you like me to add your vote to that request?
Personally I'd give a lot to be able to have shortcuts for fade in/out ...
BTW are you aware that Audacity's Normalize operates independently on each track in a stereo pair - this means that if your equipment is well balanced than using Normalize can change/damage the stereo image. I prefer to use the Amplify effect.
Re: shortcut
Post by steve » Fri Feb 04, 2011 2:42 pm
waxcylinder wrote: Personally I'd give a lot to be able to have shortcuts for fade in/out ...
Probably does not really help much so may be of academic interest only.
You can create a "Chain" command for the Fade effect, then create a shortcut for "Apply Chain", (but you still need to select the chain that you wish to run).
waxcylinder
Re: shortcut
Post by waxcylinder » Fri Feb 04, 2011 3:14 pm
Yes academically interesting but not what I really need for LP transcriptions and chop-outs from FM radio broadcasts where I need to control lots of separate fades (in and out) for each "song" in the project - and where the length of the fades has to be judged and set individually for each track.
Edgar
Forum Crew
Re: shortcut
Post by Edgar » Fri Feb 04, 2011 7:11 pm
What is "a lot" <grin>? Since you have already given so much, I would be happy to make a custom Audacity for you which has this, but...
It is easy to write a few lines of code (a function) which calls an effect (you must be careful not to add new effects later without verifying the "type & index") then put the new function into the menu and give that new function a shortcut key. I do this a lot. The only problem is that you need to be willing to trust the person doing the coding/compiling (maybe you could talk one of the Developers into reviewing any code I supplied, then compile it yourself)! Here is an example:
add a new menu item (I've added two but let's look at the easy one "My Amplifier") to menus.cpp:
Code: Select all
// Generate Menu
      c->BeginMenu(_("&Generate"));
      c->SetDefaultFlags(AudioIONotBusyFlag, AudioIONotBusyFlag);
      c->AddItem(wxT("MySilenceGenerator"),  _("My Silence Generator"), FN(OnAddSilence), wxT("Ctrl+G"));//efm5
      c->AddItem(wxT("MyAmplifier"),  _("My Amplifier"), FN(OnAmplify), wxT("Ctrl+8"));//efm5
add the support code to menus.cpp:
Code: Select all
void AudacityProject::OnAmplify()
   OnEffect(38, 0);//index = 0 type = 38
The numbers 38 and 0 (type and index) must be determined based upon inspection of code running in the debugger and would change if the order of the effects in your Audacity change)
fix the header menus.h:
Code: Select all
        // Generate & Analyze Menus
void OnAddSilence();
void OnAmplify();
That is all there is to it!
shortcut key effects.png (14.63 KiB) Viewed 813 times
