Specialty cable? 1/8" stereo to two 1/4" stereo plugs
Did you buy a new mixer? Do you need advice? Post here.
Trebor
Re: Specialty cable? 1/8" stereo to two 1/4" stereo plugs
Post by Trebor » Wed Feb 09, 2011 7:57 am
J,R,D, Ltd wrote:What do you use for making two (signal + shield) and three (signal + signal + shield) conductor cables?
The "1/8" stereo to two 1/4" stereo plugs" specification implies all the connectors are stereo,
if so then all the cables must be stereo: " (signal + signal + shield) " ...
two-core screened (stereo) cable.png (559 Bytes) Viewed 552 times
[/url]
http://www.maplin.co.uk/two-core-lap-sc ... -0.2mm-129
J,R,D, Ltd
Post by J,R,D, Ltd » Thu Feb 10, 2011 12:35 am
The attachment two-core screened (stereo) cable.png is no longer available
[/url]
All connectors are stereo but that is because I do not know of a mono connector that has tip and ring as one instead of ring and sleeve like common mono connectors.
I'm not sure my earlier description was clear, maybe this diagram will help show what I need this cable to be:
1/4"x2 to 1/8" cable diagram.
quarter-inchx2 to eighth-inch cable diagram.PNG (7.1 KiB) Viewed 544 times
PS: I am in the US so merchants based here would be preferred.
