Problem recording DJ mix
Re: Problem recording DJ mix
I will try the Maschine forum, thanks for all the advice up to now...very much appreciated
I meant Traktor
Yes, Traktor is "DJ Software". It is designed for DJs to do live DJ'ing.billw58 wrote:This appears to be primarily performance software.
The "DUO" (and other "lite" versions) are not designed to be recorded, so any success you have there is a "lucky bonus" rather than a supported feature.
The "Pro" versions have built-in recording that allow your live mixes to be recorded.
