Recording with a Telicom MIC-98-006-01
Did you buy a new mixer? Do you need advice? Post here.
TaNdOi
Post by TaNdOi » Sat Jan 29, 2011 8:46 pm
Hi everybody,
I'm writing because I want to use the mic in subject (Telicom MIC-98-006-01) in a "carpc" application.
Can I connect this mic directly to my sound card's "mic in"?
Here is the datasheet:
http://img4.imageshack.us/i/mic98006xx21ds1.png/
I've tried to use the test circuit shown at the end of the page, but it doesn't work well. Actually it has a very low volume (even raising volume up and using mic boost) with a big amount of noise.
Thank you in advance for any help.
PS: sorry for my bad english
Reason: the datasheet link was a link to external image and not an attached one so I switched the bb code from 'img' to 'url'
Re: Recording with a Telicom MIC-98-006-01
Post by steve » Sun Jan 30, 2011 5:50 pm
The data sheet is not attached, but if the microphone does not work when plugged directly into your sound card then you have probably answered your own question.
bgravato
Post by bgravato » Sun Jan 30, 2011 7:32 pm
could it be that the mic needs to be externally powered? (aka phantom power)
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
TaNdOi
Post by TaNdOi » Thu Feb 03, 2011 10:12 pm
But the "mic in" port doesn't have already a +5v power line?
bgravato
Post by bgravato » Thu Feb 03, 2011 10:23 pm
Some mics require 48V phantom power
