USB Microphone
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
mybigoldies
USB Microphone
Post by mybigoldies » Sat Jan 29, 2011 7:43 pm
Audacity isn't recognizing my USB microphone as an input. It's an AVID mic. Is there any trick I should know?
Thanks!
Re: USB Microphone
Post by steve » Sat Jan 29, 2011 9:46 pm
If you are on Vista or Windows 7 you may need to enable the microphone in the Windows Control Panel.
The USB microphone must be plugged in and enabled before you start Audacity.
Then go to "Edit menu > Preferences > Devices" and select the USB option for the Recording device. The Playback device needs to be set to your normal sound card.
