Using a MAC (Snow Leopard) with Aud Beta 1.3.10
Have my first project edited, labeled and exported.
When I play back the files in iTunes, the individual tracks did not terminate where I labeled them? At the end of track one, I hear the first .5 to 2.5 seconds of Track 2. Then iTunes advances to track 2 and I get to hear the intro again.
I'm looking for a way to turn off the 2-second gap in Audacity, but I'm not sure that's really the issue, and that's usually for the CD burner anyway.
I've searched preferences and all kinds of things looking for a solution, to no avail.
How can I assure that Audacity will actually begin and end exported tracks exactly where I mark them?
I would appreciate any help anyone can give me to point me in the right direction.
Thanks,
DAVID
HELP! Export doesn't match labels?
DavidDoesJazz
waxcylinder
Re: HELP! Export doesn't match labels?
You are probably using an earlier version of 1.3 which carried this bug. It is fixed in 1.3.12 the latest Beta, so download that from here: http://audacityteam.org/download/
Yes it was a short lived bug specific to Audacity 1.3.10waxcylinder wrote:You are probably using an earlier version of 1.3 which carried this bug.
DavidDoesJazz
You guys are awesome! Thanks!
