Getting the equalizer to work???
This section is now closed
nmuncy
Post by nmuncy » Wed Jan 26, 2011 8:18 pm
How do I start/engage the Audacity equalizer? The EQ window comes up, but I can't figure out to get the EQ happening. Thanks..
billw58
Re: Getting the equalizer to work???
Post by billw58 » Wed Jan 26, 2011 8:21 pm
Post by kozikowski » Wed Jan 26, 2011 10:57 pm
The blue/green line is a rubber band. You click on it and push. Then you click somewhere else and push again. Up is louder and down is softer. Pitch goes up to the right.
Here's one I made to help with rumble in a recording.
http://kozco.com/tech/audacity/100Hz_Rumble.jpg
Each of those little dots on the blue line is a control point and was put there by hand.
It helps get rid of sounds like a truck/lorry makes when it goes by. Officially, that's a "100 Hz High Pass Filter." You can actually buy a small device that does that in hardware made by Shure Brothers. That's where I got the idea.
http://store.shure.com/store/shure/en_U ... .104210700
