Building on OSX 10.6 Snow Leopard
Building and customizing Audacity from the source code.
bgravato
Re: Building on OSX 10.6 Snow Leopard
Post by bgravato » Fri Feb 03, 2012 5:23 pm
artm wrote: I've built wxMac 2.8.12 from the sources downloaded from wxwidgets website. I didn't realize I needed to patch it first.
I noticed it mentioned later, after Audacity was built already and is working as far as I can see. How important is the patch?
I think the patches are available only for wxMac versions up to 2.8.11.
I guess that 2.8.12 probably doesn't need the patch anymore. The fact that you were able to build Audacity without any patching seems to indicate that.
I'm trying to build Audacity on a very similar environment. I was using wxMac 2.8.11. I'll try again with 2.8.12.
Thanks.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by Gale Andrews » Sat Feb 04, 2012 1:55 am
The 2.8.11 patch
http://code.google.com/p/audacity/sourc ... 8.11.patch
is still needed for Audacity releases against 2.8.12 because it prevents a hang when Audacity scans for VST plug-ins for the first time on OS X 10.5.8 (Leopard) PPC machines. If none of your users have 10.5 PPC, you don't need the patch.
I'll see about committing the patch somewhere if it doesn't get done.
Melebius
Post by Melebius » Sat May 12, 2012 7:31 am
Hi, thanks for the instructions, especially to plivesey. It worked for me after I made a few changes. They were necessary because I do not have 10.4 SDK installed on my computer – and it is not included by default when installing Xcode from Snow Leopard Install DVD.
In the buildwx.sh script I had to change the CONF_LINE like this:
Code: Select all
CONF_LINE="../configure CC=gcc-4.0 CXX=g++-4.0 LD=g++-4.0 --prefix=${PREFIX}
                   --with-macosx-sdk=/Developer/SDKs/MacOSX10.5.sdk
                   --with-macosx-version-min=10.5 --disable-compat26
                   --with-expat=builtin --with-zlib=builtin --with-regex=builtin
                   --enable-universal_binary=yes --enable-unicode=yes"
Before building Audacity using Xcode (I was not able to build it using make), open the Audacity.xcodeproj, use Get Info on the whole project and in the Project “Audacity” Info dialog, set Base SDK to Mac OS X 10.5 on the Build page.
Patrikt
Post by Patrikt » Tue Sep 25, 2012 4:14 pm
Hi, can enyone send me a link to Mac OS SDK 1.4u? I'm registered Apple developer, but can not find this old SDK.
thx.
Post by Gale Andrews » Wed Sep 26, 2012 1:46 am
