Strange recording sound
Mun Y C
Post by Mun Y C » Sun Jan 23, 2011 8:04 am
Dear all,
I got a strange result from my recording in this laptop model Toshiba Satelite M645 where running on Window 7 home premium, enclosed sound file. What went wrong! Appreciate for help.
test 1.mp3
(174.2 KiB) Downloaded 130 times
Re: Strange recording sound
Post by steve » Sun Jan 23, 2011 1:02 pm
What is it supposed to sound like?
How did you record it? (lots of detail please)
Mun Y C
Post by Mun Y C » Tue Feb 01, 2011 12:35 pm
when using Window XP, the qualities of the sound is closed to CD. I Enclosed another sound file using XP with desktop that I recorded it from youtube. If to compare this record from the previous soud file that recorded using WIndow 7, the qualities is far from the sound file record using Window XP.
For details of the previous sound file record with Window 7 , I use the default Audacity setting to record streaming from youtube.
For the latest enclosed sound file recorded with Window XP also using the default Audacity setting to record streaming from youtube. I just copy and paste for the repeated beginning sound twice to make for ring tone.
Please advice. Hope to hear from you soon.
Chery Lady Ring Tone.mp3
Recorded with Window XP OS
(251.47 KiB) Downloaded 99 times
Post by steve » Thu Feb 03, 2011 1:51 am
My guess is that the first file (test1.mp3) has been recorded from the laptop microphone and not from "Stereo Mix".
Mun Y C
Post by Mun Y C » Fri Feb 04, 2011 7:38 am
Like others user those who in Window 7 OS, I can only find "Master" available in Audacity. For my laptop that equip with Realtek High Definition Audio soundcard , there is no other options. Is it the possible to call out "Stereo Mixer" option? Even I record play from direct CD drive, the result is the same. Any alteration can do about it? I've no idea for other user whether their record quality result is consider acceptable! I can say that if using my desktop Audacity with XP os to record any sound source and burn to cd, the quality is closed to CD.
Fellow Audacity user, any experienced can share? If possible please attach your recorded sound file to compare for my previous enclosed sound file.
Appreciate for comments.
Post by steve » Fri Feb 04, 2011 11:15 am
Mun Y C wrote:Like others user those who in Window 7 OS, I can only find "Master" available in Audacity. For my laptop that equip with Realtek High Definition Audio soundcard , there is no other options.
Microsoft are making it increasingly difficult to record "Stereo Mix". You may need to enable Stereo Mix in the Windows Control Panel (see here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel ).
If you have a Realtek High Definition control panel (look in the bottom right corner of the desktop near the time/date for a sound card icon) you may need to enable and select Stereo Mix there.
To test if your set-up is currently recording from the microphone, make a loud noise while Audacity is recording (or if you know where the in-built microphone is located you can tap it). Note that if you have an additional web-cam connected, that may also have a microphone built into it.
If the sound card and sound card drivers support Stereo Mix on Windows 7, the results should be as good as for Windows XP.
Mun Y C
Post by Mun Y C » Sat Feb 05, 2011 7:54 am
There is only 2 option in my Recording tab in Sound, 1 is Micophone & the other 1 is Stereo Mix. Currently is set to "Stereo Mix & is Enable. I try your suggestion to make a loud sound when recoding to see whether is captured, result is the purposly created loud sound is not capture. So I'm pretty sure that the microphone is at disable mode. You mention that the web cam can be the source of microphone, is it activate only when this application is using? I'm resign to it if the mobo sound system is bult to restrict in this way. But in Audacity recording source, only Master is available. Is it the same for other PC install with Window 7 os?
