remove clapping from audio
pixietrust33
i need to remove clapping from an audio track. the biggest issue is i need to remove the clapping but not the singing and music that is playing simultaneusly. i need a step by step how to fix this. thanx so much!
Re: remove clapping from audio
So do we. I think the best you can do is use Steve's Pop Mute filter from here...i need a step by step how to fix this.
http://forum.audacityteam.org/viewtopic ... 58#p122958
All that does is sense severe level peaks -- like a clap -- and reduce them to a lower value -- which you can choose in the filter. There is normally no show underneath a clap sequence. Once you get distortion or interference like that, that's the end of the show.
