how to remove a voiceover?
Hi,
I got a DVD of a sport lecture, its no commerical stuff, but unfortunately the guy that taped it does a voiceover in his language over the original english track. now i tried around with the karaoke plugin to remove the loud voiceover, but dont get any useful results.
can somebody give me a hint what to try ? the quality is not so important...since its enough to understand the original voice
my toughts are to isolate the voiceover, invert it and add it to the original track .... since i am not firm with audioediting anyway every clue is welcome ... may be there is an easier way ?
thanks!
thanks!
Re: how to remove a voiceover?
These are the three software packages that might help.
Center Pan Remover (Voice Remover--Search the page for "Center Pan Remover")
http://audacityteam.org/download/nyquistplugins
Voice Isolator (Opposite of Center Pan Remover)
Voice Trap
http://www.cloneensemble.com/vt_main.htm
Extra Boy
http://www.kvraudio.com/get/1651.html
One of the isolator packages will remove, too.
If both the voiceover and the original announcer are in the middle of the stereo field, you're dead. If the original show is in Mono, you're dead. You're not after quality, so I think those are the only two deads. If you're after high quality stereo results, then the chance of success never goes over about 20%-30% or so.
Voice Trap
Extra Boy
Thanks a lot!
I will try this the next days and report if it worked.
TheNewNumber2
Would Center Pan Remover work on something like dialogue mixed into music?
Take the sample of track 16 for example:
http://www.amazon.com/Truth-Light-Music ... B000002N8O
Could that be removed with CPR, or another way?
"You shot me! In the back; I haven't made you angry have I?"
Mal ("Serenity")
Mal ("Serenity")
"Center Pan remover" removes sound that is panned dead centre.TheNewNumber2 wrote:Would Center Pan Remover work on something like dialogue mixed into music?
Did you try it before posting your question?
Did you listen to the track?
Is the vocal a mono source panned dead centre (without any stereo effects)?
TheNewNumber2
I downloaded Center Pan Remover and tried it, but the words are still there.
Mal ("Serenity")
Mal ("Serenity")
That's because there is a massive and very obvious stereo effect on the voice-over. The voice is not in the centre, so it will not be removed by the centre pan remover. In fact, this is an excellent example of when Centre Pan Remover will not remove the vocal. http://www.amazon.com/gp/product/B00122 ... u_dp_trk16
TheNewNumber2
So, I am basically out of luck, huh? I hate it when voice sample are added to score to "enhance" it. Sorry, but it didnt' need "enhancing".
Mal ("Serenity")
Mal ("Serenity")
waxcylinder
Yup, it's just like when annoying DJs insist on speaking over the start and end of a track when you're trying to record it from FM ...
TheNewNumber2
No, not the same. I bought[/b] my CD years ago.
Mal ("Serenity")
Mal ("Serenity")
