recording album sides and dividing to separate tracks
This section is now closed
johnrichki
Post by johnrichki » Sun Jul 06, 2008 11:19 am
I'm a new user and am trying to figure out how to record an album side and then divide into separate tracks when I save to WAV. I'm using Mac OSX and the help pages make it seem like that is only possible on PC's. Does'nt seem right...........anyone have the solution? Keep it simple for this newbie if possible.
Thanks,
Re: recording album sides and dividing to separate tracks
Post by kozikowski » Sun Jul 06, 2008 8:09 pm
<<<Does'nt seem right...........anyone have the solution? Keep it simple for this newbie if possible.>>>
It's not right. The programmers are all Windows Weenies. I poke fun at them often.
Press Apple-B at the beginning of each cut you want individually identified. Then File > Export Multiple.
It won't be fancy. You'll get song1.wav, song2. wav, etc. Collect, rearrange, and dump into your CD authoring program (iTunes.) Create a PlayList and burn your brains out.
