Problem with my Ssss (sample recording included)
aussiesound
Post by aussiesound » Tue Jan 18, 2011 2:07 am
Hi guys.
Would anyone with more experience kindly tell me what to do to reduce the S on my recordings? They're too sharp, or to loud, I don't know the exact term but they're clearly annoying to the listener.
"In order to maxssssmize the ssssound quality... "
I've attached a sample of my reading. I'm using a condenser mic with a pop filter, and I'm about 10min away from the microphone.
Best,
Leo
sample-recording.mp3
Sample recording
(111.02 KiB) Downloaded 323 times
Trebor
Re: Problem with my Ssss (sample recording included)
Post by Trebor » Tue Jan 18, 2011 5:05 am
To remove this sss (sibilance) is called de-essing. There are de-esser plug-ins, (including Spitfish which is free).
However de-essing can be crudely done using equalization: by putting broad notches around 4KHz and 8Kz (approx) ...
Equalization curve used to de-ess 'in order to maximize the sound'.png (20.27 KiB) Viewed 2567 times
Have a look at the frequency analysis of the sss on its own, note any big peaks 4KHz and above, then use the equalizer to reduce these peaks, (they are the shssh sound).
BTW if you are going to install Spitfish or any other VST plug-ins, use the latest version of Audacity: 1.3 (not 1.2).
BTW2 you are too close to the mic which is causing some distortion.
Trebor
Post by Trebor » Tue Jan 18, 2011 5:54 am
Spitfish does a better job than equalization: it only applies the filter when sibilance is detected ...
' to maximize the sound' before then after de-ess using Spitfish plug-in.mp3
(146.94 KiB) Downloaded 245 times
'in order to maximize the sound quality ,,,' before then after de-ess using Spitfish plug-in.mp3
(639.79 KiB) Downloaded 256 times
Before-After spectrogram -Spitfish only applies filter when sibilance occurs, on 'Sound' 'muSt'.png
Before-After spectrogram -Spitfish only applies filter when sibilance occurs, on 'Sound' 'muSt'.png (89.54 KiB) Viewed 2560 times
aussiesound
Post by aussiesound » Wed Jan 19, 2011 8:18 am
Wow problem solved, thank you so much guys! I wasn't expecting the solution to be that easy.
Best,
Leo
